Building Haiku on Zeta
Submitted by CodeMonekyOverlord on Fri, 2006-08-18 14:58.   Tags:
Can you build a bootable HaikuOS image on Zeta? I have tried to build Haiku using the Linux build instructions and that failed to build GCC. Additionally, everytime I have tried to pull my files I checked out on Linux or Windows over, I get an error in the configure script saying that there is an invalid token at a line where there shouldn't be in the shell script (I checked in Vi, it looks clean).
Anyone do this before?
umccullough
Submitted by Urias McCullough on Fri, 2006-08-18 17:41.
You should not need the linux build instructions at all. Zeta is capable of using the 2.95.3 version of GCC posted on bebits - and regular BeOS build instructions can be followed from there:
http://www.haiku-os.org/wiki/index.php?title=Getting_Haiku
ModeenF
Submitted by Fredrik Modéen on Thu, 2007-07-05 09:49.
So any one building Haiku from Zeta? how did you do that? It says I have an old GCC and I can't get Olivers to work on Zeta.
umccullough
Submitted by Urias McCullough on Thu, 2007-07-05 21:58.
I *have* done it with Zeta 1.21 before - and I was able to use the new GCC 2.95.3 from bebits. Make sure you read the Zeta-specific instructions in the readme for that GCC - it's a little different when using it on Zeta than it is on R5.
In any case, that was some time ago when I last attempted it - maybe I'll resurrect the Haiku build environment in my (seldom-used) Zeta partition and try again. The machine I use for building Haiku runs best with R5 because it's an older machine - so I don't often use Zeta on it :)
ModeenF
Submitted by Fredrik Modéen on Tue, 2007-07-10 08:43.
The problem was BeIDE and not GCC from Haiku :)
Some one knows how to build a specific part of Haiku? like a specific driver?
umccullough
Submitted by Urias McCullough on Tue, 2007-07-10 14:52.
If you're building it for Zeta, you would use something like the following:
TARGET_PLATFORM=dano jam <drivername>
But of course - then you'd have to manually copy it.
In many cases, there is already a jam package defined in the Jamfile for many drivers, and you can simply use the jam package target name instead.
For example, building the nvidia driver would be:
TARGET_PLATFORM=dano jam haiku-nvidia-cvs
which will create a .zip containing an install script and necessary parts in the generated folder somewhere (forget exactly where)
