Driver Help needed
Forum thread started by phatpenguin on Tue, 2008-10-21 12:32
I have an old IBM thinkpad 600E that i am trying to rescue (currently running Solaris 9 on it) to use as a BeOS/Haiku box.
My trouble is that it doesn't have an ethernet port, so I was wondering if there were drivers available for ethernet or wifi pcmcia cards in BeOS or Haiku?
Re: Driver Help needed
I once ported the linux 3com megahertz driver to BONE using the xircom one as base, but never finished... it worked but KDLed on ifconfig down. But the sources are around if needed.
I have an laptop AcerTravelmate 2493WLMi, which have Broadcom 4401. I try drivers from bebits, card are initialized, but don`t work ;(
It looks like you not the only one, there is a ticket on trac about this.
http://dev.haiku-os.org/ticket/2277
Your best bet is to sign up to haiku's trac and describe how its not working for you, and nag them every fortnight 'til they reply, or that is if someone doesn't reply here :D .
There was a GPL-licensed Broadcom 44xx driver in the Haiku repository, which I used successfully on several occasions. The only issue was you had to enable gpl addons when configuring the haiku build environment (something which the public versions on haiku-files.org likely do not have).
Haiku has bcm440x driver. It's GPL & not built by default. I'm not sure why. A question for the developers to answer. This driver would likely work with your network card.
http://dev.haiku-os.org/browser/haiku/trunk/src/add-ons/kernel/drivers/n...
I just downloaded the pre-alpha and was looking at the network drivers. The pre-alpha image came with 14 network drivers but in the repository I see 23 ( two for broadcom 570 ).
I wonder why the other 8 network drivers are not part of the pre-alpha image. Another question for the developers.
Edit: jmicron is commented out so that actually leaves 7 network drivers missing from the image.
dp83815 supports a couple of cards, netgear FA-311/312 for example, but is buggy and untested, vlance just absolutely sucks, several others are older versions that have been superseded by newly ported freebsd drivers (thus why you see multiple drivers for the same cards), but they're useful to keep around in case someone wants to compile them for R5 or Zeta still (where the freebsd compat layer won't work).
Generally, anything not in the image is likely not well tested, or known to be broken.
The reason the GPL drivers are not built by default is due to licensing issues. The speculation is that by distributing GPL drivers to the general public with haiku, it will force those versions of Haiku to be provided as GPL-licensed code as well. I personally don't believe that's necessarily true, but since there's so much controversy over what definitions of "linking" and "derivatives" are when it comes with GPL, I guess it was just safer to not distribute those drivers WITH Haiku by default. Persons wishing to compile them into their own Haiku builds, or provide the drivers as separately-compiled binaries may do so.
In the worst case that would mean the resulting image would be under GPL, but that doesn't concern the sources themselves.
Thanks for the reply Urias. I thought/guessed the same but wanted to be sure this was right.
Urias wrote:
"Generally, anything not in the image is likely not well tested, or known to be broken."
Or GPL drivers :-)
I thought GPL code in the driver source would only make the driver GPL. For instance, say Haiku had 1 GPL network driver and the rest of Haiku's code was Non-GPL. Then only that network driver would fall under GPL license. That's the way I personally see it.
But I understand what you've said. That 1 GPL driver could be considered a part of Haiku itself ( not separate from the OS ) and force all of Haiku to become GPL. Tough call, hard to say which would be right.
In any case, someone should go through, compile the GPL drivers and upload them to a site like Haikuware. Can't expect normal users to download the source and compile it themselves just to obtain a missing driver.
I have an rtl8139 based card in my ThinkPad 600E that I use for random software development. It is also running Haiku, but I was under the impression that PCMCIA wasn't supported anyway?
My & Urias' comments were meant for Papa with the AcerTravelmate 2493WLMi.
Laptops with integrated ethernet, like Papa's Travelmate should work with a Haiku supported driver. Only way to get internet on laptops for now - buy one with Haiku supported, integrated ethernet chip.
PCMCIA is not available for Haiku. So, add-in cards will not work.
Thanks, i`ll try. Somebody built Haiku on OpenBSD?
So, I built Haiku with "INCLUDE_GPL_ADDONS = 1 ;".But get same as with driver from bebits.com - card are initialized, but don`t work.On OpenBSD card works well.
Ok,
1) What is your vendor & device ids for the network card? - use listdev in Haiku
2) cd into /dev/net & list folders & subfolders
3) In Network preferences can you select the network card?
4) what information does ifconfig give for the card?
5) Do you use a router? If so, assign the network card a static ip and ping the router.
With my computer my router does not work with DHCP and I have to use static ip in Haiku for networking to work.
Either, the driver is not loading for ( or recognizing/supporting ) your network card or your card is not being configured properly ( ie: can happen if you use DHCP ).
Just noticed that there might be a new broadcom driver to test out. Check out this ticket for info.
http://dev.haiku-os.org/ticket/2998
I guess the old driver was not working right for some Haiku users.
Big thanks, with new driver the card works and DHCP works :D
