get_module / put_module linker undefined reference
Hi, i'm going to write a driver for my d-link dfe-690txd pcmcia ethernet card (it is based on a realtek 8139 chip).
I've written a simple program in C that scan the pci list and return a list of vendor id and device id and (if found) the irq of the d-link card.
However, when compiling the program gcc output the following:
/tmp/ccilfp64.o: In function `main': /tmp/ccilfp64.o(.text+0x2a): undefined reference to `get_module' /tmp/ccilfp64.o(.text+0x2a): undefined reference to `put_module' collect2: ld returned 1 exit status
I've tried to compile this code with a makefile, then manually with gcc, also using -lroot and/or -ldevice. Results doesn't change.
If i compile it with the "kernel_intel" as an object passed to gcc (or as a library), the compiler error disappear, but i'm unable to execute the produced output file.
(I've also checked if this could be a permission problem, but the execute bit are all set).
Could you give me some suggestion on how to resolve this (or where i can read something in order to resolve the problem myself)?
PS: Sorry for my bad english.
Greetings,
Domenico.
Re: get_module / put_module linker undefined reference
