How do I build Haiku, in Ubuntu/Lubuntu/Puppy Linux, using Git...
Forum thread started by Luposian on Thu, 2011-12-01 21:08
I used to do my own builds of Haiku, but now I don't know what to do, because the repository has been changed from Svn to Git. How much has changed about the process? Just the download of tools/source or more? There doesn't seem to be an all-in-one document, detailing the entire build process, except mine, which is no no longer valid, because various aspects have changed. I can write up a revised one, but I need to know how much has changed and what hasn't.
This is a snippet of my most recently updated docs, based on what I think has changed, based on what I could find:
Changes are in bold.
Ready to begin? Great! Let's go!
Bring up the Terminal (it's in Application → Accessories).
Type: sudo apt-get install git autoconf automake texinfo flex bison gawk build-essential
Type in your System password and hit [Enter]. Ubuntu will download/install various files.
When you see the Terminal prompt again, type:
git clone git://git.haiku-os.org/buildtools.git haiku/buildtools
When the Terminal reappears, type:
cd haiku/buildtools/jam
make
sudo ./jam0 install
Type your System password, if necessary, on the last command.
When the Terminal prompt reappears, type:
cd ../../..
This will take you back to where Terminal started, when you first ran it.
Now type:
git clone git://git.haiku-os.org/haiku.git haiku/haiku
This will download the entire Haiku source tree.
Let me know if this is the right way to go about doing it or not. Thanks!
Re: How do I build Haiku, in Ubuntu/Lubuntu/Puppy Linux, ...
Yep it seems right to me, too :-)
You can then compile with:
jam -q
... but the last time I've tried to compile Haiku (2-3 days ago)I get a lot of build errors... and:
git pull --rebase
does nothing sadly :-(((
Is it fixed now?
I've updated now and I got this error:
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATAChannel.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATADevice.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATAHelper.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATAModule.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATAPIDevice.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATARequest.o
C++ generated/objects/haiku/x86/release/add-ons/kernel/bus_managers/ata/ATATracing.o
C++ generated/objects/haiku_host/x86/release/tools/settype.o
Link generated/objects/haiku_host/x86/release/tools/settype
Chmod1 generated/objects/haiku_host/x86/release/tools/settype
C++ generated/objects/haiku_host/x86/release/tools/mimeset.o
C++ generated/objects/haiku_host/x86/release/tools/Mime.o
C++ generated/objects/haiku_host/x86/release/tools/database_support.o
C++ generated/objects/haiku_host/x86/release/tools/UpdateMimeInfoThread.o
C++ generated/objects/haiku_host/x86/release/tools/MimeUpdateThread.o
C++ generated/objects/haiku_host/x86/release/tools/AppFileInfo.o
src/build/libbe/storage/AppFileInfo.cpp: In member function 'virtual status_t BAppFileInfo::GetType(char*) const':
src/build/libbe/storage/AppFileInfo.cpp:183:54: error: 'B_MIME_STRING_TYPE' was not declared in this scope
src/build/libbe/storage/AppFileInfo.cpp: In member function 'virtual status_t BAppFileInfo::SetType(const char*)':
src/build/libbe/storage/AppFileInfo.cpp:226:12: error: 'B_MIME_STRING_TYPE' was not declared in this scope
src/build/libbe/storage/AppFileInfo.cpp:229:40: error: 'B_MIME_STRING_TYPE' was not declared in this scope
src/build/libbe/storage/AppFileInfo.cpp: In member function 'status_t BAppFileInfo::GetSignature(char*) const':
src/build/libbe/storage/AppFileInfo.cpp:261:9: error: 'B_MIME_STRING_TYPE' was not declared in this scope
src/build/libbe/storage/AppFileInfo.cpp: In member function 'status_t BAppFileInfo::SetSignature(const char*)':
src/build/libbe/storage/AppFileInfo.cpp:304:12: error: 'B_MIME_STRING_TYPE' was not declared in this scope
src/build/libbe/storage/AppFileInfo.cpp:308:45: error: 'B_MIME_STRING_TYPE' was not declared in this scope
gcc -c "src/build/libbe/storage/AppFileInfo.cpp" -O2 -Wall -Wno-trigraphs -Wno-ctor-dtor-privacy -Woverloaded-virtual -Wpointer-arith -Wcast-align -Wsign-compare -Wno-multichar -include headers/build/HaikuBuildCompatibility.h -D_ZETA_USING_DEPRECATED_API_=1 -D_ZETA_TS_FIND_DIR_=1 -DARCH_x86 -D_NO_INLINE_ASM -DCOMPILE_FOR_R5 -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -DHAIKU_HOST_PLATFORM_HAIKU -iquote build/user_config_headers -iquote build/config_headers -iquote src/tools -iquote generated/objects/common/tools -iquote generated/objects/haiku_host/x86/common/tools -iquote generated/objects/haiku/x86/common/tools -iquote src/bin -I headers/build -I headers/build/private/app -I headers/build/private/storage -I headers/build/host/haiku_host -I headers/build/os/storage -o "generated/objects/haiku_host/x86/release/tools/AppFileInfo.o" ;
...failed C++ generated/objects/haiku_host/x86/release/tools/AppFileInfo.o ...
BUILD FAILURE:
...failed updating 1 target(s)...
...skipped 4 target(s)...
...updated 130 target(s)...
I'm doing something wrong?
I'm compilin' on Haiku itself... I suppose this release is broken :-(
I'm, in reality, interested to compile only libbe.so (Support Kit) there is a way to compile only this target and not all the Haiku image (that, incidentally not compile)?
Thanks!
