How I fixed my Haiku A3 boot problem [with help from Linux Mint]
Forum thread started by benifex on Tue, 2012-01-31 07:55
Just thought I'd share how I solved my problems getting Haiku Alpha 3 to boot. You may find the ultimate solution amusing; hopefully some may find it helpful.
I started off with a CD of Haiku that I had burned, made a partition, then installed it. However, because I had installed Windows first on my boot HDD, my bootloader was Windows Boot Loader, not GRUB, and the Haiku partition did not show up. Further, when I tried to use the CD to start the install I had on the HDD partition, it kept on acting as a Live CD. Problem.
"Fine", I thought, I'll go into my Ubuntu partition and make GRUB the bootloader, then edit the scripts per the instructions at Haiku-os.org. "How hard can it be?", I thought to myself, naively. Well, I found the Ubuntu HUD (Head Up Display) more or less impossible to use, and working out how to launch GRUB was not exactly easy.
I had been thinking about trying out Linux Mint, and it seemed like a good time .. so I downloaded the ISO, burned, and installed .. and presto, Linux Mint installed GRUB 1.99 for me and helpfully compiled a list of all the OSes I had installed. So: I have a nice list presented to me at boot time, I scroll down to Haiku, select, and boot. Problem solved.
[Did I say that _I_ solved my problem? No, I should give all credit to those user-friendly guys at Mint. Hooray for Mint!]
Re: How I fixed my Haiku A3 boot problem [with help from ...
beniflex said
> Hooray for Mint!
No : Hooray Gnu !
It's a Grub2 feature and it's available in many recent Linux distributions (Ubuntu for instance)
FWIW: Ubuntu has GRUB, but it didn't install it as the bootloader when I put in the Ubuntu partition. The bootloader remained as Windows Boot Loader. It was only when I installed Mint that GRUB was installed as the primary bootloader and Windows Boot Loader was demoted to a secondary (chain-loading) status.
I'd imagine this could vary a lot with individual setups, though.
(And yes, you are right--big thanks to the GNU guys who wrote GRUB in the first place.)
