Launchbox - Help
Forum thread started by el.tigre.20 on Fri, 2012-07-06 21:38
Hello,
quick question:
Is there any way to have Launchbox start upon startup? And for that matter is there a way to add applications to be launched at startup? I really like Launchbox as a way to keep my desktop clean, and also it's just really useful for app navigation, and every time I restart my computer, I have to launch Launchbox manually!
Thanks so much
Cheers!!
Re: Launchbox - Help
Just find LaunchBox (probably in /boot/apps) and use Tracker (Right click, Create Link In) to create a symlink to it in /boot/home/config/boot/launch. Anything in that directory is started at boot time.
http://www.haiku-os.org/docs/userguide/en/filesystem-layout.html#home
I added that feature several years ago, but clearly we need to document it better or make a simple GUI around it.
Gotta Love LaunchBox! I will be Symlinking it to my start-up too, it's on my list.
BTW, does it have any orientation features, I didn't notice any?
Best Regards - Ian
