Problem resolving host name with WebPositive
WebPositive works for reading a page of file:// designation but not http://. I get the error message "Couldn't resolve host name". I am using a router. Any suggestions would be appreciated.
I am doublebooting with Kubuntu using grub. The grub setup worked perfectly.
tcg
Re: Problem resolving host name with WebPositive
Check Network Preferences and see if your network card is listed.
If it is, try setting a static IP and manually enter your gateway and dns IPs --- see the Kubuntu network set-up if you don't know the IPs for these.
If not, what kind of network card do you have? It may not be supported in Haiku.
Good Luck
I am having the same problem running Alpha 3 in VirtualBox on OSX. Network preferences has nothing listed under devices but a network controller does show up in Devices and VirtualBox shows an active internet connection going to the VM.
