Problem to convert my application
Submitted by greg2 on Mon, 2007-10-01 19:21.   Tags:
Hi,
I want to convert one of my application to haiku. Because Haiku is not available, i use BeOs DevEd with BeIDE. But i have a problem when i compile it:
Quote:
Error : anonymous class type not used to declare any objects
AN8X.h line 143 };
This is a part of my code:
Quote:
class AN8XVECTOR4{
public:
union {
struct {
float x,y,z,w;
struct
float s,t,r,q;
AN8XVECTOR4()
x=0.0f;y=0.0f;z=0.0f;w=0.0f;
AN8XVECTOR4( float x , float y , float z, float w )
this->x = x; this->y = y; this->z = z;this->w = w;
I am not an expert in C++ but it should work ? It work very well under Linux and under Windows (Visual 2005 and DevCpp).
I have also some error with std::vector
Quote:
Error : template instantiation depth exceeds maximum of 17 stl_vector.h line 509 if(__xlen > capacity()) {
Error : (use -ftemplate-depth-NN to increase the maximum) stl_vector.h line 509 if (__xlen > capacity()) {
Error: invalid use of undefined type 'struct iterator_traits stl_iterator.h line 154 {
And many other warning ("instantiated from...") and some other error with std::vector
Is there a problem with the BeOS compiler ?
TheNerd
Submitted by TheNerd on Fri, 2007-10-05 12:48.
I'm not a developer and most of the hard core devs don't hang out a lot on the Forums. You might want to sign up to the dev mailing list, here, and post a message. You will probably get a better response.
