Running BeOS 5 PE under Bochs
Forum thread started by onepremise on Thu, 2004-07-08 22:22
I was wondering if anybody here had experience running BeOS in Bochs. I have my current setup:
# You may now use double quotes around pathnames, in case
# your pathname includes spaces.
# CONFIG_INTERFACE
# The configuration interface is a series of menus or dialog boxes that
# allows you to change all the settings that control Bochs's behavior.
# There are two choices of configuration interface: a text mode version
# called "textconfig" and a graphical version called "wx".  The text
# mode version uses stdin/stdout and is always compiled in.  The graphical
# version is only available when you use "--with-wx" on the configure
# command.  If you do not write a config_interface line, Bochs will
# choose a default for you.
# NOTE: if you use the "wx" configuration interface, you must also use
# the "wx" display library.
#config_interface: textconfig
#config_interface: wx
# DISPLAY_LIBRARY
# The display library is the code that displays the Bochs VGA screen.  Bochs
# has a selection of about 10 different display library implementations for
# different platforms.  If you run configure with multiple --with-* options,
# the display_library command lets you choose which one you want to run with.
# If you do not write a display_library line, Bochs will choose a default for
# you.
# The choices are:
#   x              use X windows interface, cross platform
#   win32          use native win32 libraries
#   carbon         use Carbon library (for MacOS X)
#   beos           use native BeOS libraries
#   macintosh      use MacOS pre-10
#   amigaos        use native AmigaOS libraries
#   sdl            use SDL library, cross platform
#   svga           use SVGALIB library for Linux, allows graphics without X11
#   term           text only, uses curses/ncurses library, cross platform
#   rfb            provides an interface to AT&T's VNC viewer, cross platform
#   wx             use wxWindows library, cross platform
#   nogui          no display at all
#display_library: amigaos
#display_library: beos
#display_library: carbon
#display_library: macintosh
#display_library: nogui
#display_library: rfb
#display_library: sdl
#display_library: term
#display_library: win32
#display_library: wx
#display_library: x
# ROMIMAGE:
# You now need to load a ROM BIOS into F0000-FFFFF. Normally, you can
# use a precompiled BIOS in the bios/ directory of the source tree,
# named BIOS-bochs-latest.
# You can also use the environment variable $BXSHARE to specify the
# location of the BIOS.
romimage: file=$BXSHARE/BIOS-bochs-latest, address=0xf0000
#romimage: file=bios/BIOS-bochs-2-processors, address=0xf0000
#romimage: file=bios/BIOS-bochs-4-processors, address=0xf0000
#romimage: file=bios/rombios.bin, address=0xf0000
# MEGS
# set this to the default number of Megabytes of memory you want
# to emulate.  You may also pass the '-megs xyz' option to bochs
# The default is 32MB, most OS's won't need more than that.
#megs: 256
megs: 128
#megs: 64
#megs: 32
#megs: 16
#megs: 8
# OPTROMIMAGE[1-4]:
# You may now load up to 4 optional ROM images. Be sure to use a
# read-only area, typically between C8000 and EFFFF. These optional
# ROM images should not overwrite the rombios (located at
# F0000-FFFFF) and the videobios (located at C0000-C7FFF).
# Those ROM images will be initialized by the bios if they contain
# the right signature (0x55AA).
# It can also be a convenient way to upload some arbitary code/data
# in the simulation, that can be retrieved by the boot loader
#optromimage1: file=optionalrom.bin, address=0xd0000
#optromimage2: file=optionalrom.bin, address=0xd1000
#optromimage3: file=optionalrom.bin, address=0xd2000
#optromimage4: file=optionalrom.bin, address=0xd3000
# VGAROMIMAGE
# You now need to load a VGA ROM BIOS into C0000.
#vgaromimage: bios/VGABIOS-lgpl-latest
#vgaromimage: bios/VGABIOS-elpin-2.40
vgaromimage: $BXSHARE/VGABIOS-elpin-2.40
# FLOPPYA:
# Point this to pathname of floppy image file or device
# This should be of a bootable floppy(image/device) if you're
# booting from 'a'.
# You can set the initial status of the media to 'ejected' or 'inserted'.
#   floppya: 2_88=path, status=ejected             (2.88M 3.5" floppy)
#   floppya: 1_44=path, status=inserted            (1.44M 3.5" floppy)
#   floppya: 1_2=path, status=ejected              (1.2M  5.25" floppy)
#   floppya: 720k=path, status=inserted            (720K  3.5" floppy)
#   floppya: 360k=path, status=inserted            (360K  5.25" floppy)
#   floppya: 320k=path, status=inserted            (320K  5.25" floppy)
#   floppya: 180k=path, status=inserted            (180K  5.25" floppy)
#   floppya: 160k=path, status=inserted            (160K  5.25" floppy)
# The path should be the name of a disk image file.  On unix, you can use
# a raw device name such as /dev/fd0 on Linux.  On WinNT and Win2k, use
# drive letters such as a: or b: as the path.  Raw floppy access is not
# supported on Windows 95 and 98.
#floppya: 1_44=/dev/fd0, status=inserted
#floppya: file=floppy.img, status=inserted
#floppya: 1_44=/dev/fd0H1440, status=inserted
#floppya: 1_2=../1_2, status=inserted
#floppya: 1_44=a:, status=inserted
floppya: 1_44=floppy.img, status=inserted
#floppya: 1_44=/dev/rfd0a, status=inserted
# FLOPPYB:
# See FLOPPYA above for syntax
#floppyb: 1_44=b:, status=inserted
floppyb: 1_44=floppy.img, status=inserted
#floppya: file=./beos/floppy.img, status=inserted
# ATA0, ATA1, ATA2, ATA3
# ATA controller for hard disks and cdroms
# ata[0-3]: enabled=[0|1], ioaddr1=addr, ioaddr2=addr, irq=number
# These options enables up to 4 ata channels. For each channel
# the two base io addresses and the irq must be specified.
# ata0 is enabled by default, with ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
# Examples:
#   ata0: enabled=1, ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
#   ata1: enabled=1, ioaddr1=0x170, ioaddr2=0x370, irq=15
#   ata2: enabled=1, ioaddr1=0x1e8, ioaddr2=0x3e0, irq=11
#   ata3: enabled=1, ioaddr1=0x168, ioaddr2=0x360, irq=9
ata1: enabled=0, ioaddr1=0x170, ioaddr2=0x370, irq=15
ata2: enabled=0, ioaddr1=0x1e8, ioaddr2=0x3e0, irq=11
ata3: enabled=0, ioaddr1=0x168, ioaddr2=0x360, irq=9
# ATA[0-3]-MASTER, ATA[0-3]-SLAVE
# This defines the type and characteristics of all attached ata devices:
#   type=       type of attached device [disk|cdrom]
#   mode=       only valid for disks [flat|concat|external|dll|sparse|vmware3]
#   mode=       only valid for disks [undoable|growing|volatile]
#   path=       path of the image
#   cylinders=  only valid for disks
#   heads=      only valid for disks
#   spt=        only valid for disks
#   status=     only valid for cdroms [inserted|ejected]
#   biosdetect= type of biosdetection [none|auto], only for disks on ata0 [cmos]
#   translation=type of transation of the bios, only for disks [none|lba|large|rechs|auto]
#   model=      string returned by identify device command
#   journal=    optional filename of the redolog for undoable and volatile disks
# Point this at a hard disk image file, cdrom iso file, or physical cdrom
# device.  To create a hard disk image, try running bximage.  It will help you
# choose the size and then suggest a line that works with it.
# In UNIX it may be possible to use a raw device as a Bochs hard disk,
# but WE DON'T RECOMMEND IT.  In Windows there is no easy way.
# In windows, the drive letter + colon notation should be used for cdroms.
# Depending on versions of windows and drivers, you may only be able to
# access the "first" cdrom in the system.  On MacOSX, use path="drive"
# to access the physical drive.
# The path, cylinders, heads, and spt are mandatory for type=disk
# The path is mandatory for type=cdrom
# Default values are:
#   mode=flat, biosdetect=auto, translation=auto, model="Generic 1234"
# The biosdetect option has currently no effect on the bios
# Examples:
#   ata0-master: type=disk, mode=flat, path=10M.sample, cylinders=306, heads=4, spt=17
#   ata0-slave:  type=disk, mode=flat, path=20M.sample, cylinders=615, heads=4, spt=17
#   ata1-master: type=disk, mode=flat, path=30M.sample, cylinders=615, heads=6, spt=17
#   ata1-slave:  type=disk, mode=flat, path=46M.sample, cylinders=940, heads=6, spt=17
#   ata2-master: type=disk, mode=flat, path=62M.sample, cylinders=940, heads=8, spt=17
#   ata2-slave:  type=disk, mode=flat, path=112M.sample, cylinders=900, heads=15, spt=17
#   ata3-master: type=disk, mode=flat, path=483M.sample, cylinders=1024, heads=15, spt=63
#   ata3-slave:  type=cdrom, path=iso.sample, status=inserted
ata0-master: type=disk, mode=flat, path="image.be", cylinders=1065, heads=16, spt=63
#ata0-slave: type=cdrom, path=D:, status=inserted
#ata0-slave: type=cdrom, path=/dev/cdrom, status=inserted
#ata0-slave: type=cdrom, path="drive", status=inserted
#ata0-slave: type=cdrom, path=/dev/rcd0d, status=inserted
# BOOT:
# This defines your boot drive.
# You can either boot from 'floppy', 'disk' or 'cdrom'
# legacy 'a' and 'c' are also supported
# Examples:
#   boot: floppy
#   boot: disk
#   boot: cdrom
#   boot: c
#   boot: a
boot: floppy
#boot: disk
# IPS:
# Emulated Instructions Per Second.  This is the number of IPS that bochs
# is capable of running on your machine.  Read the note in config.h
# on how to find this.  Make sure to recompile after.
# IPS is used to calibrate many time-dependent events within the bochs
# simulation.  For example, changing IPS affects the frequency of VGA
# updates, the duration of time before a key starts to autorepeat, and
# the measurement of BogoMips and other benchmarks.
# Examples:
# Machine                                         Mips
# ________________________________________________________________
# 650Mhz Athlon K-7 with Linux 2.4.4/egcs-2.91.66 2 to 2.5 Mips
# 400Mhz Pentium II with Linux 2.0.36/egcs-1.0.3  1 to 1.8 Mips
# 166Mhz 64bit Sparc with Solaris 2.x             approx 0.75 Mips
# 200Mhz Pentium with Linux 2.x                   approx 0.5 Mips
ips: 600000
# CLOCK:
# This defines the parameters of the clock inside Bochs:
#  SYNC:
#  TO BE COMPLETED (see Greg explaination in bug #536329)
#  TIME0:
#  Specifies the start (boot) time of the virtual machine. Use a time
#  value as returned by the time(2) system call. If no time0 value is
#  set or if time0 equal to 1 (special case) or if time0 equal 'local',
#  the simulation will be started at the current local host time.
#  If time0 equal to 2 (special case) or if time0 equal 'utc',
#  the simulation will be started at the current utc time.
# Syntax:
#  clock: sync=[none|slowdown|realtime], time0=[timeValue|local|utc]
# Example:
#   clock: sync=none,     time0=local       # Now (localtime)
#   clock: sync=slowdown, time0=315529200   # Tue Jan  1 00:00:00 1980
#   clock: sync=none,     time0=631148400   # Mon Jan  1 00:00:00 1990
#   clock: sync=realtime, time0=938581955   # Wed Sep 29 07:12:35 1999
#   clock: sync=realtime, time0=946681200   # Sat Jan  1 00:00:00 2000
#   clock: sync=none,     time0=1           # Now (localtime)
#   clock: sync=none,     time0=utc         # Now (utc/gmt)
# Default value are sync=none, time0=local
#clock: sync=none, time0=local
# FLOPPY_BOOTSIG_CHECK: disabled=[0|1]
# Enables or disables the 0xaa55 signature check on boot floppies
# Defaults to disabled=0
# Examples:
#   floppy_bootsig_check: disabled=0
#   floppy_bootsig_check: disabled=1
#floppy_bootsig_check: disabled=1
# LOG:
# Give the path of the log file you'd like Bochs debug and misc. verbage
# to be written to.  If you really don't want it, make it /dev/null. :^(
# Examples:
#   log: ./bochs.out
#   log: /dev/tty
#log: /dev/null
log: bochsout.txt
# LOGPREFIX:
# This handles the format of the string prepended to each log line.
# You may use those special tokens :
#   %t : 11 decimal digits timer tick
#   %i : 8 hexadecimal digits of cpu0 current eip
#   %e : 1 character event type ('i'nfo, 'd'ebug, 'p'anic, 'e'rror)
#   %d : 5 characters string of the device, between brackets
# Default : %t%e%d
# Examples:
#   logprefix: %t-%e-@%i-%d
#   logprefix: %i%e%d
#logprefix: %t%e%d
# LOG CONTROLS
# Bochs now has four severity levels for event logging.
#   panic: cannot proceed.  If you choose to continue after a panic,
#          don't be surprised if you get strange behavior or crashes.
#   error: something went wrong, but it is probably safe to continue the
#          simulation.
#   info: interesting or useful messages.
#   debug: messages useful only when debugging the code.  This may
#          spit out thousands per second.
# For events of each level, you can choose to crash, report, or ignore.
# TODO: allow choice based on the facility: e.g. crash on panics from
#       everything except the cdrom, and only report those.
# If you are experiencing many panics, it can be helpful to change
# the panic action to report instead of fatal.  However, be aware
# that anything executed after a panic is uncharted territory and can
# cause bochs to become unstable.  The panic is a "graceful exit," so
# if you disable it you may get a spectacular disaster instead.
panic: action=ask
error: action=report
info: action=report
debug: action=ignore
#pass: action=fatal
# DEBUGGER_LOG:
# Give the path of the log file you'd like Bochs to log debugger output.
# If you really don't want it, make it /dev/null or '-'. :^(
# Examples:
#   debugger_log: ./debugger.out
#debugger_log: /dev/null
#debugger_log: debugger.out
debugger_log: -
# COM1:
# This defines a serial port (UART type 16550A). You can specify a device
# to use as com1. This can be a real serial line, or a pty.  To use a pty
# (under X/Unix), create two windows (xterms, usually).  One of them will
# run bochs, and the other will act as com1. Find out the tty the com1
# window using the `tty' command, and use that as the `dev' parameter.
# Then do `sleep 1000000' in the com1 window to keep the shell from
# messing with things, and run bochs in the other window.  Serial I/O to
# com1 (port 0x3f8) will all go to the other window.
#com1: enabled=1, dev=/dev/ttyp9
# PARPORT1:
# This defines a parallel (printer) port. When turned on and an output file is
# defined the emulated printer port sends characters printed by the guest OS
# into the output file. On some platforms a device filename can be used to
# send the data to the real parallel port (e.g. "/dev/lp0" on Linux, "lpt1" on
# win32 platforms).
# Examples:
#   parport1: enabled=1, file="parport.out"
#   parport1: enabled=1, file="/dev/lp0"
#   parport1: enabled=0
# SB16:
# This defines the SB16 sound emulation. It can have several of the
# following properties.
# All properties are in the format sb16: property=value
# midi: The filename is where the midi data is sent. This can be a
#       device or just a file if you want to record the midi data.
# midimode:
#      0=no data
#      1=output to device (system dependent. midi denotes the device driver)
#      2=SMF file output, including headers
#      3=output the midi data stream to the file (no midi headers and no
#        delta times, just command and data bytes)
# wave: This is the device/file where wave output is stored
# wavemode:
#      0=no data
#      1=output to device (system dependent. wave denotes the device driver)
#      2=VOC file output, incl. headers
#      3=output the raw wave stream to the file
# log:  The file to write the sb16 emulator messages to.
# loglevel:
#      0=no log
#      1=only midi program and bank changes
#      2=severe errors
#      3=all errors
#      4=all errors plus all port accesses
#      5=all errors and port accesses plus a lot of extra info
# dmatimer:
#      microseconds per second for a DMA cycle.  Make it smaller to fix
#      non-continous sound.  750000 is usually a good value.  This needs a
#      reasonably correct setting for IPS.
# For an example look at the next line:
#sb16: midimode=1, midi=/dev/midi00, wavemode=1, wave=/dev/dsp, loglevel=2, log=sb16.log, dmatimer=600000
# VGA_UPDATE_INTERVAL:
# Video memory is scanned for updates and screen updated every so many
# virtual seconds.  The default is 300000, about 3Hz.  This is generally
# plenty.  Keep in mind that you must tweak the 'ips:' directive
# to be as close to the number of emulated instructions-per-second
# your workstation can do, for this to be accurate.
# Examples:
#   vga_update_interval: 250000
vga_update_interval: 300000
# using for Winstone '98 tests
#vga_update_interval:  100000
# KEYBOARD_SERIAL_DELAY:
# Approximate time in microseconds that it takes one character to
# be transfered from the keyboard to controller over the serial path.
# Examples:
#   keyboard_serial_delay: 200
keyboard_serial_delay: 250
# KEYBOARD_PASTE_DELAY:
# Approximate time in microseconds between attempts to paste
# characters to the keyboard controller. This leaves time for the
# guest os to deal with the flow of characters.  The ideal setting
# depends on how your operating system processes characters.  The
# default of 100000 usec (.1 seconds) was chosen because it works
# consistently in Windows.
# If your OS is losing characters during a paste, increase the paste
# delay until it stops losing characters.
# Examples:
#   keyboard_paste_delay: 100000
# FLOPPY_COMMAND_DELAY:
# Time in microseconds to wait before completing some floppy commands
# such as read/write/seek/etc, which normally have a delay associated.
# I had this hardwired to 50,000 before.
# Examples:
#   floppy_command_delay: 50000
# MOUSE:
# This option prevents Bochs from creating mouse "events" unless a mouse
# is  enabled. The hardware emulation itself is not disabled by this.
# You can turn the mouse on by setting enabled to 1, or turn it off by
# setting enabled to 0. Unless you have a particular reason for enabling
# the mouse by default, it is recommended that you leave it off.
# You can also toggle the mouse usage at runtime (middle mouse button on
# X11 and SDL, F12 on Win32).
# Examples:
#   mouse: enabled=1
#   mouse: enabled=0
mouse: enabled=0
# private_colormap: Request that the GUI create and use it's own
#                   non-shared colormap.  This colormap will be used
#                   when in the bochs window.  If not enabled, a
#                   shared colormap scheme may be used.  Not implemented
#                   on all GUI's.
# Examples:
#   private_colormap: enabled=1
#   private_colormap: enabled=0
# fullscreen: ONLY IMPLEMENTED ON AMIGA
#             Request that Bochs occupy the entire screen instead of a
#             window.
# Examples:
#   fullscreen: enabled=0
#   fullscreen: enabled=1
#fullscreen: enabled=0
#screenmode: name="sample"
# ne2k: NE2000 compatible ethernet adapter
# Examples:
# ne2k: ioaddr=IOADDR, irq=IRQ, mac=MACADDR, ethmod=MODULE, ethdev=DEVICE, script=SCRIPT
# ioaddr, irq: You probably won't need to change ioaddr and irq, unless there
# are IRQ conflicts.
# mac: The MAC address MUST NOT match the address of any machine on the net.
# Also, the first byte must be an even number (bit 0 set means a multicast
# address), and you cannot use ff:ff:ff:ff:ff:ff because that's the broadcast
# address.  For the ethertap module, you must use fe:fd:00:00:00:01.  There may
# be other restrictions too.  To be safe, just use the b0:c4... address.
# ethdev: The ethdev value is the name of the network interface on your host
# platform.  On UNIX machines, you can get the name by running ifconfig.  On
# Windows machines, you must run niclist to get the name of the ethdev.
# Niclist source code is in misc/niclist.c and it is included in Windows
# binary releases.
# script: The script value is optionnal, and is the name of a script that
# is executed after bochs initialize the network interface. You can use
# this script to configure this network interface, or enable masquerading.
# This is mainly useful for the tun/tap devices that only exist during
# Bochs execution. The network interface name is supplied to the script
# as first parameter
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=fbsd, ethdev=en0 #macosx
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:00, ethmod=fbsd, ethdev=xl0
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:00, ethmod=linux, ethdev=eth0
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:01, ethmod=win32, ethdev=MYCARD
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=tap, ethdev=tap0
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=tuntap, ethdev=tun0, script=./tunconfig
# KEYBOARD_MAPPING:
# This enables a remap of a physical localized keyboard to a
# virtualized us keyboard, as the PC architecture expects.
# If enabled, the keymap file must be specified.
# Examples:
#   keyboard_mapping: enabled=1, map=gui/keymaps/x11-pc-de.map
keyboard_mapping: enabled=0, map=
# KEYBOARD_TYPE:
# Type of keyboard return by a "identify keyboard" command to the
# keyboard controler. It must be one of "xt", "at" or "mf".
# Defaults to "mf". It should be ok for almost everybody. A known
# exception is french macs, that do have a "at"-like keyboard.
# Examples:
#   keyboard_type: mf
#keyboard_type: mf
# USER_SHORTCUT:
# This defines the keyboard shortcut to be sent when you press the "user"
# button in the headerbar. The shortcut string can be a combination of
# these key names: "alt", "bksp", "ctrl", "del", "esc", "f1", "f4", "tab"
# and "win". Up to 3 keys can be pressed at a time.
# Example:
#   user_shortcut: keys=ctrlaltdel
#user_shortcut: keys=ctrlaltdel
# other stuff
#magic_break: enabled=1
#cmosimage: cmos.img
#load32bitOSImage: os=nullkernel, path=../kernel.img, iolog=../vga_io.log
#load32bitOSImage: os=linux, path=../linux.img, iolog=../vga_io.log, initrd=../initrd.img
#i440fxsupport: enabled=1
usb1: enabled=1, ioaddr=0xFF80, irq=10
#text_snapshot_check: enable
# for Macintosh, use the style of pathnames in the following
# examples.
# vgaromimage: :bios:VGABIOS-elpin-2.40
# romimage: file=:bios:BIOS-bochs-latest, address=0xf0000
# floppya: 1_44=[fd:], status=inserted
# The following directives are DEPRECATED
# Please convert them to the new syntax  or remove them
# The DISKC option is deprecated. Use ATA* options instead.
# DISKC: file=, cyl=, heads=, spt=
# Point this at a hard disk image file.  To create
# a hard disk image, try running bximage.  It will help you choose the
# size and then suggest a diskc line that works with it.
# Examples:
#   diskc: file=10M.sample, cyl=306, heads=4, spt=17
#   diskc: file=20M.sample, cyl=615, heads=4, spt=17
#   diskc: file=30M.sample, cyl=615, heads=6, spt=17
#   diskc: file=46M.sample, cyl=940, heads=6, spt=17
#   diskc: file=62M.sample, cyl=940, heads=8, spt=17
#   diskc: file=112M.sample, cyl=900, heads=15, spt=17
#   diskc: file=483M.sample, cyl=1024, heads=15, spt=63
#diskc: file="30M.sample", cyl=615, heads=6, spt=17
# The DISKD option is deprecated. Use ATA* options instead.
# DISKD:
# See DISKC above for syntax
# NOTE: diskd and cdromd must not be used together!
#diskd: file="diskd.img", cyl=615, heads=6, spt=17
# The CDROMD option is deprecated. Use ATA* options instead.
# CDROMD:
# cdromd: dev=/dev/cdrom, status=inserted
# cdromd: dev=/dev/cdrom, status=ejected
# cdromd: dev=e:, status=ejected
#cdromd: dev=D:, status=inserted
#cdromd: dev=/dev/cdrom, status=inserted
#cdromd: dev="drive", status=inserted
# The TIME0 directive is DEPRECATED. Use the CLOCK directive instead
# TIME0:
# set or if time0 equal to 1 (special case), the simulation will be
# started at the current time of the host.
# Examples:
#   time0: 1           # Now
#   time0: 315529200   # Tue Jan  1 00:00:00 1980
#   time0: 631148400   # Mon Jan  1 00:00:00 1990
#   time0: 938581955   # Wed Sep 29 07:12:35 1999
#   time0: 946681200   # Sat Jan  1 00:00:00 2000
#time0: 938581955
# The PIT directive is DEPRECATED. Use the CLOCK directive instead
# PIT:
# The PIT is the programmable interval timer.  It has an option that tries to
# keep the PIT in sync with real time.  This feature is still experimental,
# but it may be useful if you want to prevent Bochs from running too fast, for
# example a DOS video game.  Be aware that with the realtime pit option, your
# simulation will not be repeatable; this can a problem if you are debugging.
#pit: realtime=1
# NEWHARDDRIVESUPPORT: enabled=[0|1]
# The old harddrive code is not maintened any more.
# Default value is enabled=1
#newharddrivesupport: enabled=1
The config file loads fine and I can even start the emulation:
Then the kernel boots:
From there on its stuck on that screen. It will not respond to anything. Is there anybody else here that uses Bochs emulator for BeOS? Any input will help. If I get this working, I might be able to create a tutorial for others :D
Re: Running BeOS 5 PE under Bochs
I do not have a soulution for using Boch's.. But I do know that Microsoft's Viritual PC software can run BeOS R5 in Windows.
As Viritual PC is available for MAC this might be your solution.
http://www.microsoft.com/mac/products/virtualpc/virtualpc.aspx
And of course, you may prefer a non MS Product...
You could ha
