- Google Summer of Code project: Sub-pixel anti-aliasing
- Google Summer of Code Project: Alternate System Timers
- Anthy Ported to Haiku, Binary Available on Bebits
- Premonitions of a rising sun
- GSoc Swap File Project
- Google Summer of Code Project : Writing a CIFS client
- Google Summer of Code: Zeroconf!
- Git for Haiku (#1)
- A weekend in SF, for LugRadio Live USA 2008
- Haiku Websites Stats and Other Trivia
Running SVN on Haiku
I am trying to get SVN to work on Haiku and when I type any command with SVN in it I get the following error messages.
svn: error: cannot set LC_ALL locale
svn: error: environment variable LANG is not set
svn: error: please check that your locale is set
Anyone know if this can be fixed?
Thanks
I have seen the same issue while trying to run Perl, setting LANG didn't help either.
Did you ever solve the problem?
Nope, I'm new to Haiku and don't have an R5 to compare to. I just ignored it.
How did you get Subversion compiled for Haiku anyway? The compilation of the apr-util dependency under Haiku always took me to KDL and corrupted the filesystem so that I had to overwrite the image...
Did you cross-compile from Linux? Do you have any pointers how to do so outside Haiku's Jam build environment?
I'm guessing anyone testing SVN on Haiku is probably just taking advantage of the binary-compatibility with R5 and copying it from their R5 partition/install rather than recompiling it for Haiku.
It should theoretically be possible (assuming all the headers are correct and necessary tools are present) to compile it for Haiku as well.
I believe that is what Karl VD did (copied from a R5 version). He was the one who installed it on the Haikuware Super Pack on Haikuware.com.
Well I spoke to the good folks on IRC (#haiku) and was told to try
export LANG=en_US or export LANG=C
Neither worked. Any suggestions?
