Here's how to get Haiku to work in Parallels:
- Download a nightly build from the Haiku Build Factory.
- Rename the "haiku.image" file to "haiku.hdd".
- Use ImageTool to resize the haiku.hdd file to 120MB.
- Create a new VM in Parallels, with Guest OS Type as Windows.
- Set the Hard Drive to the haiku.hdd file that you downloaded.
Some have reported that Haiku hangs when booting unless you disable the Parallels network interface. Looks like some issue with the etherpci driver maybe.
