Application (QT) without sound
Forum thread started by Giova84 on Wed, 2012-05-02 02:30
Hi,
I have installed Cuberok (a QT app) on Haiku.
Is this app: http://goo.gl/T0rdu (is a cached page because qt-haiku.ru is temporary unavailable)
Ok, i have all needed libs (QT and SDL), but i don't hear no sound from Cuberok.
Looking at this screenshot i have noticed a thing:
http://qt-haiku.ru/images/rsgallery/original/cuberok-0.0.11_ffmpeg_sdl_b...
In AboutDialog we can read "Current plugin: FFmpeg". But In my aboutdialog i just read: "null engine" and nothing about FFmpeg. But i have FFmpeg installed on my system and In Cuberock's folder there is a file called libplayer_ffmpeg.so, i've also tried to create a "plugins" folder in Cuberok's directory, and renamed libplayer_ffmpeg.so to player_ffmpeg.so but this solve nothing. I miss something? Someone has Cuberok installed on Haiku? If someone want to try, this is download link: http://qt-haiku.ru/rokdownloads/qtapps/Multimedia/Cuberok_0.0.11.zip
Thanks.
Re: Application (QT) without sound
It's working for me using A1R3 with Qt 4.7.3 installed.
I notice that in my /boot/apps/Cuberok folder there's a link to /boot/system/add-ons/media/plugins/ffmpeg.
Also in the /boot/apps/Cuberok folder is the file: libplayer_ffmpeg.so
Also in the folder: /boot/apps/Cuberok/lib are the following fiiles:
libSDL-1.2.so.0
libavcodec.so.52
libavformat.so.52
libavutil.so.50
I hope this helps.
Regards,
hey68you.
Hi hey68you,
Thank you!
The difference of my setup are: Haiku hrev44070, QT 4.8.0, and the absence of link to /boot/system/add-ons/media/plugins/ffmpeg in Cuberok folder. I linked this file but still i not heard no sound. Then i have downgraded QT to 4.7.3 and now Cuberok works at 100%!
Best regards.
