I've installed Haiku on a 2GB Kingston USB stick. I hold down the Option key at boot-up but my MacBook Pro just won't spot the USB stick. Any help appreciated.
there are some problems with some Kingston USB stick. see: http://dev.haiku-os.org/ticket/4135
Did you try any other USB stick ?
Thanks very much for pointing that out. I'll try another stick. Cheers
Re: Booting in using USB stick on MacBook Pro
see:
