checking out Open Sound
Forum thread started by El-Al on Sun, 2007-11-18 10:09
Quickie. How does one checkout the opensound source from the tree? Ant info/instructions anywhere?
Thanks.
Re: checking out Open Sound
The OpenSound source itself is not actually in the Haiku repository. The only piece that's in the haiku repo is the media node that Francois created as an adapter from haiku's driver model to the OpenSound engine.
You'll probably get more info if you ask on the development mailing list - as Francois reads those message, and likely doesn't read these.
Oh! Ok! Must have miss-read the check-in comment then. ;o)
