Compilling intel_extreme driver for r5
Forum thread started by knorr on Thu, 2006-04-20 06:34
Hello
1. i've got source of intel_extrem from cvs and try to build it for r5 (5.0.3+BONE)
2. some errors while linking
undefined reference to '__throw'
in intel_extreme
and so on.
3. if linking (only as experiment, i understand that r5 driver can't be linked with shared library ) with libroot.so - everything fine, but warning message in system log (/var/log/system)
intel_extreme is linked against libroot.so
as expected
Some solutions?? faq?? howto??
p.s.
sorry about my english.
thanks
Re: Compilling intel_extreme driver for r5
knorr wrote:
Hello
in intel_extreme
and so on.
as expected
p.s.
thanks
You might not get much help from the forums on that one. That is the code Axel checked into SVN - and he is usually accessible on #haiku, or via the mailing lists.
es ist shade
i'm behind http proxy, cannot use IRC
in intel_extreme
and so on.
as expected
Are you using the Haiku Build System? Have you grabbed the respitory or have you just grapped the driver?
