Cross compiling beyond building a image
Forum thread started by ToraBora on Thu, 2009-04-23 13:59
Hello,
i currently try to set up a cross development environment on linux to build Haiku/BeOS Applications. I've read the Articles concerning on how to get the latest sources from SVN, build Jam and bootstrap the compiler to target haiku - that's no problem at all and works relativley flawless. So does building targets with Jam (like haiku-image, ...)
But: Now that i have the cross compiler, how to compile a simple application on linux using the cross compiler? When i try to compile a simple application like the obligatory "Hello, World" there are a few issues:
(Please note that i am not a GCC Guru - just used the installed, native compilers until now)
1.) The compiler does not find the necessary header files from the standard c++ libs - you have to supply them by hand using the -I switch or set the CPLUS_INCLUDE_PATH variable to the corresponding directory. Is this something i can configure in some configuration file?
2.) The linker complains that he's missing crti.o and some other bootstrapping objects. They are there somewhere deep inside the "generated/" folder - you have to copy them to the directories where ld looks for them (found out the correct path's via strace)
3.) When linking the libstdc++.r4.so and libbe.so there are a huge amount of missing references -> That's where i stuck at the moment.
So, would it be possible that someone explains (or eventually writes a nice tutorial) on how to get a simple Haiku Application (like let's say "Pulse") to compile on linux and run on haiku?
Thanks,
ToraBora
