Hi all,
how can I use bluetooth with haiku and what I need for that.
Thanks, René
It is in a very early state.
If I remember correctly you need to install the Bluetooth Optional Package.
https://www.haiku-os.org/guides/daily-tasks/installoptionalpackage
Thank you for your answer, but "bluetooth" does not shown under the optional packages.
René
Right, Bluetooth is an optional package that must be added during compiling Haiku. i.e., add it to your UserBuildConfig while doing a custom build.
But the only thing you can do now are paring devices. No other thing are implemented..
Re: Haiku and Bluetooth ?
René
