Haiku networking problem.
Forum thread started by jaydc on Mon, 2009-09-21 01:27
Hi,
First I want to thank the Haiku dev team for the incredible work they've done. It's wonderfull to see a BeOS like OS running on modern hardware.
Well, I have installed Haiku alpha 1 on my Compaq mini 700 ef, and it's working quite well, but I have a strange problem with the network.
On fresh boot, network is Ok, but after using the network for less than a minute, I loose all the network.
Is there any solution for this ?
Re: Haiku networking problem.
What driver does that use?
There is one driver that disconnects after a short while, I can't remember the drivers name that I was on trac.
(trac: http://dev.haiku-os.org)
try static ip to see if that works
You should file a ticket to have a developer look into it. Make sure to give your network card information which you can get through "listdev" in terminal.
Finaly I found some trace on Trac.
Same hardware as me (Broadcom).
Thanks for answering me.
