You can install Web Positive - as well a host of additional apps using the installoptionalpackages command in terminal.
If memory serves type installoptionalpackages -l to list all the packages available for install (although installoptionalpackages -? should give you a syntax list)
Re: How to get Web Positive? Why is it not in Nightly Builds?
Hi tj,
Hope that helps.
