How to get WebPositive to work with VMWare Fusion on OS X
Forum thread started by macsociety on Wed, 2010-06-23 16:35
Any trick to get WebPositive or any Internet apps to work on a virtual machine using VMWare Fusion on OS X? I am on the newest Haiku VM that has WebPositive but it appears to not tag onto the OS X internet settings to get on the net.
tj
Re: How to get WebPositive to work with VMWare Fusion on OS X
Did you create a VM in VMware Fusion or are you using the pre-made VM from this site? If you used the VM from this site it should work without a problem(it worked for me in Fusion 2). If you created your own VM in VMware Fusion you need to change the network adapter to "e1000" in the VMX file. Here is a how-to link for you:
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd...
ethernet0.virtualDev = "e1000"
That worked. Thanks!
BTW, I did get the VM from here but had to add that new text anyway.
tj
