Trying to get BeOS up and running on my system again but can't find anything to actually format my drive to BFS.
Zeta doesn't have a partition manager, can't seem to boot BeOSMax install CD even with the RAM limiter.
Any ideas?
Hi,
create a ext2 or other filesystem partition and then start the installer of beos. Then select the partition in the installer and the installer format the partition into bfs before installing the system.
Greetings Lelldorin
Re: How to format for BFS
Hi,
Greetings Lelldorin
