I do not obtain to initiate Haiku
Forum thread started by Dernival Luna on Tue, 2010-05-18 01:32
Good night! I installed Haiku in trial boot with Windows XP and a GNU/Linux distribution, to put I am not obtaining to after initiate to edit the Grub placing an entrance for Haiku. The entrance in grub is thus: Considering that I installed in /dev/sda9.
# Entered for Haiku system
# on /dev/sda9
title Haiku
root (hd0,8)
to chainloader +1
What it would be making made a mistake?
Yours truly,
Dernival Luna/Brazil
Re: I do not obtain to initiate Haiku
Try installing to a primary partition and not extended....also it should be just chainloader +1 and not 'to chainloader +1'
otherwise that looks fine what method did you use to install? livecd ....or from svn trunk? or did you attemt to dd a disk image to your partition? risos....eu divia ter respondido em portugese ;-)
Hello,
Putting Haiku on a logical partition is perfectly OK. I have an instance installed on it. And I boot it with GRUB (legacy). My code is:
title Haiku
root (hd0,8) # yes, Haiku is on the 9-th partition too
savedefault # to point to Haiku by default on next boot
chainloader +1
It boots without trouble.
Success,
Alexandru
You possibly forgot to do a makebootable. How did you install Haiku?
