is it possible to change the font color for the icon labels? Since they are white, on a light background it's not really noticable. Is it possible to have them on a different background color so it wouldn't interfere with the wallpaper?
The icon label changes to black on a light colored background. This is controlled by the background color, not the color of the wallpaper. If one changes to a light colored wallpaper and does not change the background color, the text stays white.
Re: icon labels: problem with some wallpapers
Have you tried the 'icon label outline' option in Backgrounds preferences?
I seem to recall there was a utility for that waaaaayyyy back in the BeOS R3 days. Maybe somebody still has the code and could compile it.
of course there is this "icon label outline" option... why didn't I try/see it ? Thank you very much, it's better now!
The background color tips is good too, even if on some mixed wallpaper, I still prefer to use a dark color background.
Try darker your background color, like 101, 101, 101 colors (will be grayed) then put the lighter wall
