I see an inputkit package there. Hopefully Sikosis fixed the TARGET_PLATFORM=r5 issue by now (at one point, it was building all the packages for Haiku, not R5).
That said, I would be extremely careful applying this to your R5 system, as it may render it unusable. Make sure you have a boot CD, or some method to fix it if it doesn't work right.
Looks like it's on the factory
Usually, the R5 versions of Haiku components are distributed as "jam packages" on the Haiku Build Factory:
http://factory.haiku-os.org/
Thank you!
Thank you!
