Intel Centrino Wireless 2200
Forum thread started by sysek on Mon, 2014-05-19 09:57
Hello to everyone !
Is there any possible to get work this wifi chips on Haiku R4 ? I am looking for new OS, i get sick of linux, windows.
Re: Intel Centrino Wireless 2200
https://www.haiku-os.org/guides/daily-tasks/wireless#hardware-notes
https://www.haiku-os.org/docs/userguide/en/workshop-wlan.html
Supported Hardware
All of FreeBSD 9.2 WLAN drivers except aironetwifi should be working.
atheroswifi supporting almost every Atheros chipset out there (Except for the AR9285)
broadcom43xx supporting
Broadcom BCM4301
Broadcom BCM4306
Broadcom BCM4307
Broadcom BCM4309
Broadcom BCM4311
Broadcom BCM4312
Broadcom BCM4318
ipw2100 supporting Intel Pro Wireless 2100
iprowifi2200 supporting
Intel Pro Wireless 2200BG
Intel Pro Wireless 2225BG
Intel Pro Wireless 2915ABG
iprowifi3945 supporting Intel Pro Wireless 3945
iprowifi4965 supporting Intel Pro Wireless 4965
http://cgit.haiku-os.org/haiku/commit/src/add-ons/kernel/drivers/network...
Welcome to the family :) It should work. https://dev.haiku-os.org/wiki/HardwareInfo What problem do you have?
It should work.
that problem, the haiku do not se my device ;) I see on wiki there's an ipro2000 drivers, but I have intel centrino n wireless (and also do not work on FreeBSD :( )
maybe I do something wrong. Maybe I will try today switch my laptop to LAN cable and then run install-wifi-firmwares.sh
Welcome to the Haiku shell.
~> listdev
vendor 1969: Qualcomm Atheros
device 1083: AR8151 v2.0 Gigabit Ethernet
vendor 168c: Qualcomm Atheros
device 002b: AR9285 Wireless Network Adapter (PCI-Express)
I do not know about alpha4, but in recent nightlies there was a bug, which is fixed now as http://cgit.haiku-os.org/haiku/commit/?id=hrev47242
https://dev.haiku-os.org/ticket/10464
If it don't work in FreeBSD it won't be working in Haiku ether. You could test a nightlys as pistooli says. I would test the lates. Still don't work make a ticket and search FreeBSD and se if they have a solution for it. If so report the solution to the ticket.
it should work in the latest nightlies. I have an oldish Thinkpad X31, where the miniPCI is upgraded to ipw2000 and it works. :)
