after fiddling around and messing with replicant, i replicated one of the cpu on-off buttons in Pulse onto the desktop. To my dismay there was no wrench to get rid of it. Any manual way of disposing of unwanted replicants?
BT,DT,GTTS - extra desktop pager I couldn't seem to shed OR get a menu for all week.
You're gonna hate this next part...
Just grab it in the lower right corner where a teeny-tiny icon shows and drag the sucker to the trash can and drop it.
Gone.
No harm to its 'parent', even if open elsewhere.
Oh the irony unintuitive and yet... so easy
Actually, I think this is a known bug/issue: that the pulse CPU replicants don't have handles on them.
http://dev.haiku-os.org/ticket/4244
Yeh, that's the issue i have :|
as i said, any way of getting rid of them manually?
nvm, deleted tracker_shelf as said in the bug report and it's fixed the problem. Thanks anyway :)
Re: Issue with a replicant.
Gone.
