Is it possible to programmatically change Web+ settings?
I'm looking to build a script I can chuck in git and just clone/run every time I pick up a new nightly and set up some basics for me. One of the things I'd like to do is modify the Web+ settings to put Goodsearch as the search engine. I noticed the settings are stored in a binary file, though. Is there any way of modifying these programmatically? Otherwise I'll just have to take the whole blob and stick that in the repo, which is a little risky as the structure may change between versions. I suppose I just backup the existing settings before I overwrite...
Looks like I've solved it myself, lol, but if anyone does know a programmatic way to do it I'd be very grateful!
Re: Is it possible to programmatically change Web+ settings?
Brilliant! Thanks for the information. I've learnt two new things about Haiku today!
