Login system for Haiku
Forum thread started by Giova84 on Fri, 2013-05-10 20:45
Hi,
since i started to use Haiku i was feeling a lack of a system to protect Haiku with a login screen.
When i was using BeOS, there was a nice app called LockWorkstation, but unfortunately doesn't work anymore on Haiku. But now i have recompiled and improved this app (new graphic, support to high monitor resolution and a system to keep track of every access)
Maybe someone else can find useful this app:
http://haikuware.com/directory/view-details/utilities/system-system-info...
Login system for Haiku>
Re: Login system for Haiku
I like the idea of being able to lock the workstation! If someone needed to take a bathroom break and did not want people snooping around their files, this would be a great way to stop them! I am going to install it and do some personal testing. Thank you!
You can also add it to startup :-)
Wow, I am impressed! I did not realize that it would require you to login at every boot! This is awesome! I do have one problem. The first time I attempted to login, I could not use the mouse to select the password field. I had to use the tab key to shift to it. Could this be fixed, or is this a problem with my setup?
Thanks
Mouse click is disabled inside text fields: you can only use TAB on your keyboard. I will add this to readme :-)
