Need some help getting Haiku installed on R5!
Firstly, sorry to be posting this as it's bound to be in an FAQ or have been discussed here many times in the past. :oops:
I've got R5.0.3 installed and I'd like to build the various Haiku packages so I can have a play with them. I understand that it's best to have BONE installed first so my first question is - where do I find BONE?
Next, I've been reading some of the info regarding the Haiku packages, but is there a step-by-step guide to getting them built and installed?
Thanks in advance
Sorry - ignore this. I've tracked down bone 7a (I'm guessing this is the most current version) and I've found mahlzeit's getting started guide so I'll try this out tonight!
I do, however, reserve the right to post more inane noobie questions here as and when appropriate. :wink:
You can test ready-built packages from the build factory - the link is in a topic in the website team forum I think.
I don't think BONE is required - in fact Haiku are targetting source/binary compatiblily with plain R5 net_server.
Should work under either I think.
They are however using a kernelland POSIX compliant networking stack... where have we heard that before?
Finally managed to checkout and build the current source tree! net_server kept falling over (couldn't find any particular cause/pattern, except that it would happen after roughly 10 minutes). I also started getting 'bad pipe' or similar errors so I downloaded and installed BONE 7a - after that it ran through fine.
I built the full tree and had a look at a few of the apps (CD player appears as an empty window on my system?) and I'll have a further look later this week. Of course, now the Haiku team have announced a move away from CVS I'll be waiting for the newbie guide to SubVersion!
:wink:
