network problem
Forum thread started by zvacet on Sat, 2009-09-26 15:30
I can not establish internet connection on Haiku.It is kernel driver /dev/net/rtl8169/0 .I tried DHCP and static with no joy.can somebody help me to resolve this one?
Re: network problem
I am using the 8139 ( best one for Beos and Zeta) with the latest firmware. Didn't have to do a thing , installed automatically!
Re: network problem
Good for you,but that doesn´t solve my problem.I have http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?P... motherboard.Does this help in any way?Right now I run Haiku from Virtual box but I will like to solve this to run it from hard drive.
Re: network problem
I had a motherboard with rtl8169 and networking worked. This was about 2 to 3 years back though but it should still work.
If you're running in VMDK you should search for information to get networking going in it. Search the site & you'll find helpful info.
If you install Haiku to hard drive & run it natively & rtl8169 does not work then you should file a bug ticket with your output from "listdev" command.
http://dev.haiku-os.org
You likely don't have networking done right under Virtual Box.
Re: network problem
I have no problems running Haiku from Vbox.Problem is how to establish internet connection when Haiku is installed on hard drive.I´m glad that is seams to work,so I will file a bug ticket to see if that is right way to sort it.If someone get idea how to fix this don´t be ashamed to say it.
Re: network problem
Search & check out the other rtl8169 tickets. There are open ones, for instance,
http://dev.haiku-os.org/ticket/4550
http://dev.haiku-os.org/ticket/2801
Maybe others. I only looked quickly. Add to these if your issue is similar, otherwise create new ticket.
From memory, I used to run with static ip ( believe dhcp gave issues for me ) on 100 mbit router.
Re: network problem
I tried static too with no result.I used same address,DNS... as I do in Ubuntu.It look I will have to file a bug ticket.
Re: network problem
I tried to file bug but I have to login and I get info that username & password are invalid.How can it be?I tried to reset password but with no luck.What is going on?
Re: network problem
Check your spam for the authentication email from Trac.
Re: network problem
I know this is away from my original question,but I can write here.That means I˙m registered and I have account,right?Why I can not use same account when I try to file a bug?No,message is not in the spam folder,because when I try to reset password I don´t get any e-mail.Instead of that window pop up with the message that no username and e-mail address is attached to any account or something similar.Do I need to have separate account If I want to file bug?
Re: network problem
Trac and the haiku website have two independent account mechanisms; this was once not true.
Re: network problem
@ richienyhus
Thank you.Now it is solved (login).But feel free to laugh,because I hit the wall again.Now when I have account I don´t know how to use it.In short I don´t know how to add comment to ticket or open new one.More I read less I understand.Is this to big for me or I´m just new.I don´t know any more.
Re: network problem
Gday zvacet
After reading this: http://dev.haiku-os.org/wiki/AccountVerificationEmail (just in case)
Go here: http://dev.haiku-os.org/newticket , you will need to login.
Enter a Summary, Description and change the Component to drivers > network.
Hope this helps,
~Richie
Re: network problem
@ richienyhus
Thank you!Everything works as it should.It must be hard to talk with such a noob like myself,but one last question about this.I want to attach text files in ticket(listdev,ifconfig) for better understanding and possible help.I just don't know how to do it.I looked but I didn't find a way.Sorry for my ignorance and thanks one more time.
Re: network problem
There's a checkbox like "I have files to attach to the ticket" below the summary textbox. Mark it before submitting the ticket and you'll be directed to a page where you can upload files.
Re: network problem
Sorry for late response.I was busy with other things.I searched little and I found http://dev.haiku-os.org/ticket/1853.I would like to know if that patch is included in r1alpha1 release.
1.if it is not how to apply it
2.if it is I will file ticket because it doesn´t work for me.
Thanks for your time and patience.
Re: network problem
zvacet if you file a bug report and I am guessing it was bug 4571 I have added my own bug to yours.
You motherbaord has a realtek 8111c for the Lan chip. Mine has a realtek 8111b chip for it's Lan. Thinking that revisions of the chip might be a problem for the Haiku driver.
Have our fingers crossed for both of us :)
bug 4571
http://dev.haiku-os.org/ticket/4751
Nos
Re: network problem
bug 4571
Nos
Re: network problem
Thanks to tonestone57 I have it working now I change 2 things at once in bios and when I booted Haiku it worked :)
For others with gigabyte GA-P35-DS3/S3 mother board 2 things I did was select the option in the bios for "Smart Lan" and place "boot on lan" as the third boot device. don't know why that would cause it to work after checking my manual again or placing lan as a boot option even after the hard drive
zvzcet try doing "Smart Lan" (downloaded your motherboard manual) option under your bios
and the placing boot lan as one of your boot options.
Re: network problem
Great to hear you got it working. You're lucky that other person posted a similar issue with solution.
I wouldn't have thought of it myself because very weird that it only works this way - must set the hardware up a different way and so it works. Go figure.
Re: network problem
@ nos
I tried what you told.I went to "Smart Lan" and after that select "lagacy LAN" as my third boot option.Reboot and start Haiku.Still doesn´t work.
Re: network problem
@ tonestone57
"Try going into BIOS and changing to On with PXE boot."
Sorry for my ignorance but I just don´t know where to look under BIOS to find that option if I have it.
"If you can ping your router, ie: 192.168.1.1, then networking is working and you have a DNS issue to figure out."
In Ubuntu I can ping several DNS including OPenDNS but in Haiku I can not ping any of them.So,I don´t think it is DNS issue.I can be wrong also.
Re: network problem
I use nforce drivers
And for many times I had to do a ctrl+alt+del, close net_serve and force reeboot. shutdown modem, wait, force reboot again
and it works
Re: network problem
Look for settings relating to on-board network card or LAN in BIOS. It'll one of those. Usually the one that says On, Off, On with PXE. Or it may be another setting? Smart LAN? (first time I've heard of this one).
Someone else said that when network card was turned to On, networking did not work in Haiku but by changing setting to On w/PXE it worked.
The way to tell if you have networking is by pinging the router.
For instance, if router is at 192.168.1.1 and your ip is 192.168.1.25. If you ping 192.168.1.1 and it comes back successful then you ping a site, like www.tomshardware.com & it fails it is DNS issue.
If you ping (router) 192.168.1.1 & it fails, then networking issue (ie: driver not working for you ).
You should file a ticket, http://dev.haiku-os.org, include listdev output for network card & syslog from /boot/var. Also check in /dev ( /dev/net? /dev/network? ) to see if driver loaded & which one.
Re: network problem
Sorry for late response.I file ticket http://dev.haiku-os.org/ticket/4751.I tried what nos suggested but with no luck.Here is my situation in short using two Os
1.Ubuntu
I have working internet connection
I can ping my ISP DNS and OpenDNS and several others including link you gave as example
2.Haiku
I can ping my gateway
I can not ping nameserver witch I use in Ubuntu
I can not ping any of my ISP nameservers or OpenDNS
Under /dev/net I found rtl 8169 driver
Re: network problem
It look like route print problem.Can anybody help me to put correct info to the route print to finally get internet working in Haiku?See http://dev.haiku-os.org/ticket/4751
Re: network problem
Have you ever tried setting the dns ip to match the gateway?
Re: network problem
Tnx for response.I tried that too after your suggestion,but with no luck.It is become frustrating when you know that it should work but it doesn´t.
Re: network problem
After long time it is working.Maybe it is new modem,I don‘t know and don‘t really care. Now I can start learning how Haiku works.Tanks to all who helped me with advices and suggestions.
