No network connection with Gigabit RTL 8168B
Forum thread started by rama65 on Mon, 2013-05-13 09:44
Hi there,
I´m new to Haiku, using it for about one week and am impressed of its speed and the consistent environment. After HD-installation everything was fine, but no network connection. The network adapter does not appear in the device list of network configuration.
Here are the details of
listdev
  vendor 10ec: Realtek Semiconductor Co., Ltd.
  device 8168: RTL8111/8168B PCI Express Gigabit Ethernet controller
and related lines from syslog file:
KERN: rtl81xx: init_driver(0xcd730ed8)
KERN: [rtl81xx] (re) bus_alloc_resource(3, [24], 0x0, 0xffffffff, 0x1,0x2)
KERN: add_memory_type_range(3071, 0xfdfff000, 0x20000, 0)
KERN: set MTRRs to:
KERN:   mtrr:  0: base:    0xef000, size:     0x1000, type: 0
KERN:   mtrr:  1: base: 0xcfe80000, size:    0x80000, type: 0
KERN:   mtrr:  2: base: 0xe0000000, size: 0x20000000, type: 0
KERN:   mtrr:  3: base: 0xd0000000, size: 0x10000000, type: 1
KERN: [rtl81xx] (re) MSI count : 1
KERN: [rtl81xx] (re) MSI-X count : 0
KERN: allocate_io_interrupt_vectors: allocated 1 vectors starting from 24
KERN: msi_allocate_vectors: allocated 1 vectors starting from 24
KERN: [rtl81xx] (re) Using 1 MSI message
KERN: [rtl81xx] (re) bus_alloc_resource(1, [1], 0x0, 0xffffffff, 0x1,0x2)
KERN: [rtl81xx] (re) Chip rev. 0x48000000
KERN: [rtl81xx] (re) MAC rev. 0x00000000
KERN: [rtl81xx] (re) Unknown H/W revision: 0x48000000
KERN: loaded driver /boot/home/config/add-ons/kernel/drivers/dev/net/rtl8139
KERN: loaded driver /boot/home/config/add-ons/kernel/drivers/dev/net/rtl8169
KERN: runtime_loader: Cannot open file libcrypto.so.0.9.8: No such file or directory
KERN: devfs: reload driver "rtl8169" (3, 3193029)
KERN: devfs: reload driver "rtl8139" (3, 3148230)
KERN: rtl8139: init_driver
KERN: init_driver: rtl8139 not found
KERN: PCI:   class_base 02, class_function 00, class_api 00
KERN: PCI:   vendor 10ec: Realtek Semiconductor Co., Ltd.
KERN: PCI:   device 8168: RTL8111/8168B PCI Express Gigabit Ethernet controller
KERN: PCI:   info: Network controller (Ethernet controller)
KERN: PCI:   line_size 10, latency 00, header_type 00, BIST 00
KERN: PCI:   ROM base host 00000000, pci 00000000, size 00000000
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 8505, subsystem_vendor_id 1043
KERN: PCI:   interrupt_line 0a, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 0000e800, pci 0000e800, size 00000100, flags 01
KERN: PCI:   base reg 1: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 2: host fdfff000, pci fdfff000, size 00001000, flags 0c
KERN: PCI:   base reg 3: host 00000000, pci 00000000, size 00000010, flags 0f
KERN: PCI:   base reg 4: host fdff8000, pci fdff8000, size 00004000, flags 0c
KERN: PCI:   base reg 5: host 00000000, pci 00000000, size 00000010, flags 0f
KERN: PCI:   Capabilities: PM, MSI, PCIe, MSI-X, VPD
KERN: etherpci: init_driver init_driver: etherpci not found
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/net/pegasus
KERN: add_memory_type_range(3115, 0xfdfff000, 0x20000, 0)
KERN: set MTRRs to:
I searched in the Haiku source tree if my device is supported and found that it should be.
Maybe the problem is the hardware revision number. Haiku found 0x480000000, in the source for RTL81XX I found three spins with three different revision numbers
SPIN1 0x30000000
SPIN2 0x38000000
SPIN3 0x38400000
All of these numbers are different to mine. I don´t know what spin I have.
How can I find it out? And how can I change it in the driver?
BTW: I couldn´t read that the RTL81XX driver was loader, is it?
Hoping for your help!!
Re: No network connection with Gigabit RTL 8168B
It seems that your H/W revision 0x48000000 is supported in current version:
http://cgit.haiku-os.org/haiku/tree/src/add-ons/kernel/drivers/network/r...
Try a nightly image http://haiku-files.org/haiku/development/
http://dev.haiku-os.org/ticket/9131 seems related too.
Thanks for your instant reply Diver!
Does it matter that the H/W revision 0x480000000 is assigned to the RTL8168F (and not B)?
And if I can use it, how to go on. Do I have to compile the driver new? Sorry for that maybe stupid question, but I'm really a newbie...
A short instruction or link to it was very helpful to me.
Best regards...
rama65
Just go to http://haiku-files.org/haiku/development/ and download the latest nightly image and install it.
The nightly image didn´t work. The boot ends up in the KDM-console ... :-(
rama65
Could you post the KDL message? Or rather take a photo?
The message is:
PANIC: did not find any boot partitions!
Welcome ...
Thread 18 "main2" running on CPU 0
stack trace for thread 18 "main2"
kernel stack: 0x8242f000 to 0x82433000
Is this the required information?
rama65
The KDL you encountered is a different problem than your network card. You can eventually submit a bug report if the problem persists (you need to know which revision/version was working before, which isn't anymore).
