Onboard graphics card problem? (Sony VAIO)
Forum thread started by Ezprezo on Wed, 2011-12-21 17:28
Hello everybody. I wanted to try out Haiku on my old hobby computer, which is a Sony VAIO VGN-FZ140E.
As you can see in this picture: http://i.imgur.com/5xoqi.jpg there is quite a problem, and I am not sure what it is. I am assuming it's a graphics card problem, so is there any current way to fix this issue, or is this computer simply not compatible yet? Thank you ahead of time for any help I receive.
Sony Vaio VGN Fz140e
Intel Centrino Duo
Processor Processor Intel Core 2 Duo T7100 / 1.8 GHz
Chipset Type Mobile Intel GM965 Express
RAM Installed Size 2 GB / 4 GB (max)
Technology DDR2 SDRAM - 667 MHz
Memory Specification Compliance PC2-5300
Storage Hard Drive 200 GB - Serial ATA-150 - 4200 rpm
Video Graphics Processor / Vendor Intel GMA X3100 Dynamic Video Memory Technology 4.0
Total Available Graphics Memory 358 MB
Features Sound Reality technology
Wireless NIC Intel Wireless WiFi Link 4965AGN
Re: Onboard graphics card problem? (Sony VAIO)
I suspect it's due to this current ticket:
http://dev.haiku-os.org/ticket/8001
Once that ticket is resolved, I suspect your display will work just fine.
I had a similar problem with my first attempt of an install but when I switched to a lower spec monitor it worked fine. I think bog standard video drivers are being used and they don't always support the monitor as well as they might. Try switching monitor.
