Problem booting Haiku from USB drives
I have a 16 gigabyte USB thumb/flash drive and an 80 gigabyte USB external hard and Haiku will not boot from either of them. I have the option to boot from usb drives enabled in the B. I. O. S.. I have to load bootman from the cd and then tell it to boot from the usb drive. I suppose this is a good alternative, but I don't think this willl do as R1
Re: Problem booting Haiku from USB drives
I can boot my PCs from USB, it does work. Can you try to boot off the 16 GB flash drive from some different PCs?
What PC are you trying to boot from?
The symptoms you describe are as if the PC can't really boot from BIOS. Can you install Linux on the flash drive and try that?
You can copy the Haiku's MBR from the anyboot raw image with a command like:
NB : adapt the «
of» parameter to your USB drive.
