Problems with building Haiku coss-compiler
Forum thread started by tombhadAC on Wed, 2007-10-24 01:32
Can anybody help me?
mkdir -p -- ./intl
Configuring in ./intl
creating cache ./config.cache
checking for a BSD compatible install... /bin/install -c
checking how to run the C preprocessor... gcc -E
checking whether make sets ${MAKE}... yes
checking for gcc... gcc
checking whether the C compiler (gcc -O2 ) works... yes
checking whether the C compiler (gcc -O2 ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for ranlib... ranlib
checking for POSIXized ISC... no
checking for ANSI C header files... yes
checking for working const... yes
checking for inline... inline
checking for off_t... yes
checking for size_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for unistd.h... yes
checking for getpagesize... yes
checking for working mmap... yes
checking for argz.h... yes
checking for limits.h... yes
checking for locale.h... yes
checking for nl_types.h... yes
checking for malloc.h... yes
checking for string.h... yes
checking for unistd.h... (cached) yes
checking for values.h... yes
checking for sys/param.h... yes
checking for getcwd... yes
checking for munmap... yes
checking for putenv... yes
checking for setenv... yes
checking for setlocale... yes
checking for strchr... yes
checking for strcasecmp... yes
checking for __argz_count... yes
checking for __argz_stringify... yes
checking for __argz_next... yes
checking for stpcpy... yes
checking for LC_MESSAGES... yes
checking whether NLS is requested... no
updating cache ./config.cache
creating ./config.status
creating Makefile
creating config.h
linking /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/intl/libgettext.h to libintl.h
make[2]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/intl'
make[2]: F\u00fcr das Ziel \u00bball\u00ab ist nichts zu tun.
make[2]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/intl'
make[2]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd'
Making info in doc
make[3]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/doc'
make chew
make[4]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/doc'
gcc -o chew.$$ /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/chew.c \
-O2 \
-I.. -I/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/.. -I/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../include -I/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../intl -I../../intl; \
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change chew.$$ chew
make[4]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/doc'
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str aoutx.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change aoutx.tmp aoutx.texi
make chew
make[4]: \u00bbchew\u00ab ist bereits aktualisiert.
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str archive.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change archive.tmp archive.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../archures.c >archures.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change archures.tmp archures.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../bfd.c >bfd.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change bfd.tmp bfdt.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../cache.c >cache.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change cache.tmp cache.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str coffcode.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change coffcode.tmp coffcode.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str core.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change core.tmp core.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str elf.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change elf.tmp elf.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str elfcode.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change elfcode.tmp elfcode.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str format.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change format.tmp format.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../libbfd.c >libbfd.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change libbfd.tmp libbfd.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../bfdwin.c >bfdwin.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change bfdwin.tmp bfdwin.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../bfdio.c >bfdio.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change bfdio.tmp bfdio.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str opncls.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change opncls.tmp opncls.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str reloc.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change reloc.tmp reloc.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str section.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change section.tmp section.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str syms.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change syms.tmp syms.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str targets.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change targets.tmp targets.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str init.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change init.tmp init.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str hash.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change hash.tmp hash.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str linker.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change linker.tmp linker.texi
make chew
./chew -f /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/doc.str mmo.tmp
/bin/sh /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/../../move-if-change mmo.tmp mmo.texi
restore=: && backupdir=".am$$" && \
am__cwd=`pwd` && cd /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc && \
rm -rf $backupdir && mkdir $backupdir && \
for f in /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info-[0-9] /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info-[0-9][0-9] /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.i[0-9] /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.i[0-9][0-9]; do \
if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
done; \
cd "$am__cwd"; \
if /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/missing makeinfo --split-size=5000000 --split-size=5000000 -I /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc \
-o /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.texinfo; \
then \
rc=0; \
cd /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc; \
else \
rc=$?; \
$restore $backupdir/* `echo ".//home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info" | sed 's|[^/]*$||'`; \
fi; \
rm -rf $backupdir; exit $rc
WARNING: `makeinfo' is missing on your system. You should only need it if
you modified a `.texi' or `.texinfo' file, or any other file
indirectly affecting the aspect of the manual. The spurious
call might also be the consequence of using a buggy `make' (AIX,
DU, IRIX). You might want to install the `Texinfo' package or
the `GNU make' package. Grab either from any GNU archive site.
mv: Verschieben von \u201e.am22664/bfd.info\u201c nach \u201e.//home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/\u201c nicht m\u00f6glich: Datei oder Verzeichnis nicht gefunden
make[3]: *** [/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/doc/bfd.info] Fehler 1
make[3]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/doc'
Making info in po
make[3]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/po'
( if test 'x/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/po' != 'x.'; then \
posrcprefix='/home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/'; \
else \
posrcprefix="../"; \
fi; \
rm -f SRC-POTFILES-t SRC-POTFILES \
&& (sed -e '/^#/d' \
-e '/^[ ]*$/d' \
-e "s@.*@ $posrcprefix& \\\\@" < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/po/SRC-POTFILES.in \
| sed -e '$s/\\$//') > SRC-POTFILES-t \
&& chmod a-w SRC-POTFILES-t \
&& mv SRC-POTFILES-t SRC-POTFILES )
( rm -f BLD-POTFILES-t BLD-POTFILES \
-e '/^[ ]*$/d' \
-e "s@.*@ ../& \\\\@" < /home/tombhad/Projects/HAIKU/buildtools/legacy/binutils/bfd/po/BLD-POTFILES.in \
| sed -e '$s/\\$//') > BLD-POTFILES-t \
&& chmod a-w BLD-POTFILES-t \
&& mv BLD-POTFILES-t BLD-POTFILES )
cd .. \
&& CONFIG_FILES=po/Makefile.in:po/Make-in \
CONFIG_HEADERS= /bin/sh ./config.status
config.status: creating po/Makefile.in
config.status: executing depfiles commands
config.status: executing default commands
make[3]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd/po'
make[3]: F\u00fcr das Ziel \u00bbinfo\u00ab ist nichts zu tun.
make[3]: Entering directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd'
make[3]: F\u00fcr das Ziel \u00bbinfo-am\u00ab ist nichts zu tun.
make[3]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd'
make[2]: *** [info-recursive] Fehler 1
make[2]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils/bfd'
make[1]: *** [all-bfd] Fehler 2
make[1]: Leaving directory `/home/tombhad/Projects/HAIKU/source/generated/cross-tools-build/binutils'
make: *** [all] Fehler 2
Re: Problems with building Haiku coss-compiler
Install the texinfo package and try again
Perhaps this will help:
http://haiku-os.org/documents/dev/building_haiku_on_ubuntu_linux_step_by...
texinfo is already installed :(
[tombhad@amdAC source]$ pacman --query | grep texinfo
texinfo 4.11-1
[tombhad@amdAC source]$ makeinfo --version
makeinfo (GNU texinfo) 4.11
Bummer - I'm not sure then :(
Every time I've seen that error, it's usually due to lack of texinfo.
What Linux are you on? It's not 64-bit is it?
My system is ArchLinuX - Don't Panic (current) and its i686 not x86_64.
OK found that on the trac: http://dev.haiku-os.org/ticket/1581
