Processor - idle missing !!! Help!!!
~> sysinfo
Kernel name: kernel_x86 built on: Aug 24 2014 17:04:07 version 0x1
4 Intel Core™ i3-2330M, revision 206a7 running at 2195MHz
CPU #0: "Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz"
Raw CPUID: 0x0206a7, Type 0, family 6, model 42, stepping 7, features 0xbfebfbff
FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT
PSE36 CFLUSH DS ACPI MMX FXSTR SSE SSE2 SS HTT TM PBE
Extended Intel: 0x15bae3bf
SSE3 PCLMULDQ DTES64 MONITOR DS-CPL VMX EST TM2 SSSE3 CX16 xTPR PDCM PCID SSE4.1 SSE4.2 x2APIC
POPCNT TSC-DEADLINE XSAVE AVX
Extended AMD: type 0, family 0, model 0, stepping 0, features 0x28100000
NX RDTSCP 64
Power Management Features:
L2 Data cache fully associative, 1 lines/tag, 64 bytes/line
L2 cache: 0 KB, 1-way set associative, 0 lines/tag, 63 bytes/line
Data TLB: 2M/4M-bytes pages, 4-way set associative, 32 entries
Data TLB: 4k-byte pages, 4-way set associative, 64 entries
Unknown cache descriptor 0x76
Unknown cache descriptor 0xff
Inst TLB: 4K-bytes pages, 4-way set associative, 64 entries
64-byte Prefetching
Shared 2nd-level TLB: 4K, 4-way set associative, 512 entries
Update hrev47738 -- hrev47748 ...... No words other than obscene . CPU usage is zero. The cooling fan operates at the limit . Exhaust air is very hot. On hrev47738 - all right !!
Re: Processor - idle missing
Welcome to the Haiku shell.
~> listdev
device Serial bus controller (SMBus) [c|5|0]
device 1c22: 6 Series/C200 Series Chipset Family SMBus Controller
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device 1c03: 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller
device 1c49: HM65 Express Chipset Family LPC Controller
device Serial bus controller (USB controller, EHCI) [c|3|20]
device 1c26: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
device 1c16: 6 Series/C200 Series Chipset Family PCI Express Root Port 4
device Serial bus controller (USB controller, XHCI) [c|3|30]
vendor 1106: VIA Technologies, Inc.
device 3432: VL80x xHCI USB 3.0 Controller
device 1c14: 6 Series/C200 Series Chipset Family PCI Express Root Port 3
vendor 1969: Qualcomm Atheros
device 1083: AR8151 v2.0 Gigabit Ethernet
device 1c12: 6 Series/C200 Series Chipset Family PCI Express Root Port 2
device 088e: Centrino Advanced-N 6235
device 1c10: 6 Series/C200 Series Chipset Family PCI Express Root Port 1
device 1c20: 6 Series/C200 Series Chipset Family High Definition Audio Controller
device 1c2d: 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
device Communication controller [7|80|0]
device 1c3a: 6 Series/C200 Series Chipset Family MEI Controller #1
device 0116: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor 10de: NVIDIA Corporation
device 0ded: GF108M [GeForce GT 520M]
device 0101: Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port
device Bridge (Host bridge) [6|0|0]
device 0104: 2nd Generation Core Processor Family DRAM Controller
Re: Processor - idle missing !!! Help!!!
The correct place for this is at https://dev.haiku-os.org/ to file a ticket. Devs won't necessarily notice issues like this posted in the forums.
Hi,
just as info, they already working on it. I have the same problem on my machine.
https://dev.haiku-os.org/ticket/11174
libroot: remove ATOMIC_FUNCS_ARE_SYSCALLShrev47741
GCC knows whether these functions need to be implemented using syscalls
(or more clever solutions like in Linux) and calls libgcc in such case.
Signed-off-by: Paweł Dziepak <pdziepak@quarnos.org>
http://cgit.haiku-os.org/haiku/commit/?id=hrev47741
kernel/x86_64: use C++11 style static asserthrev47742
http://cgit.haiku-os.org/haiku/commit/?id=hrev47742
Possible candidates are:
btrev43089
hrev47741
hrev47742
comment: by edglex
I also have this problem on hrev47826 with an i5-3230M
It puts the hardware in danger of overheating. I wouldn't want to run a computer that way.
Update to hrev48031 x86_gcc2 -- no bug.
Update to hrev48060 x86_gcc2 -- no bug.
Update to hrev48068 x86_gcc2 -- no bug.
Update to hrev48074 x86_gcc2 -- retry bug!!! http://buildbot.haiku-os.org/buildslaves/arfonzo-bot1-debian
Update to hrev48086 x86_gcc2 -- no bug!!!
Update to hrev48100 x86_gcc2 -- retry bug!!! http://buildbot.haiku-os.org/buildslaves/arfonzo-bot1-debian
Update to hrev48433 x86_gcc2 -- no bug
Update to hrev48440 x86_gcc2 -- BUG !!! http://buildbot.haiku-os.org/builders/haiku-repository-x86_gcc2_hybrid/b...
Please keep us updated...
Update to hrev48444 -- bug! http://buildbot.haiku-os.org/builders/haiku-repository-x86_hybrid/builds...
Update to hrev48446 -- bug!
Update to hrev48448 -- bug!
Update to hrev48455 -- bug!
Update to hrev48472 -- bug!
