running .vmdk in virtualbox is causing errors
I'm having problems running haiku's .vmdk files within virtualbox. Everything is fine if I don't move the mouse and haiku will go to the desktop, but If I do, I get these errors:
and this one:
I was using virtualbox 2.1.0 and the latest haiku development vmware image(dec. 22)
Re: running .vmdk in virtualbox is causing errors
Can you try the command "bt"?
That will give more information about the problem.
I did provide that information in the pictures.
Sorry about that, I saw: "bd"; unknown command, and just presumed.
You should create a ticket on trac (http://dev.haiku-os.org/), if you have yet to do so.
ok I made a bug report. http://dev.haiku-os.org/ticket/3233
