Solution: nForce2 audio
Forum thread started by NicePics13 on Sun, 2006-10-01 02:50
Some time ago I asked the members of this forum how to get rid of the hissing noise emanating from the line-out/headphone jack of my onboard sound chip on Dano/Zeta.
And wouldn't you know it? Haiku saves the day :wink:
1. Rename or move the generic ich_ac97 driver
2. Install Haiku's auich driver and multi_audio addon. (new mixer if wanted) They'll be installed locally in your home folder, so no risk of overwriting anything
--- I'm using the ones from http://jerome.duval.free.fr/obos/, the latest from CVS should also work, yes?
3. Reboot and now you'll be able to lower your Master and PCM volume from max (!) to more normal levels
Re: Solution: nForce2 audio
NicePics13 wrote:
2. Install Haiku's auich driver, mixer and multi_audio addon. They'll be installed locally in your home folder, so no risk of overwriting anything
If you want, try the Haiku build factory jam packages located here:
http://haiku-os.org/factory
Those should be newer versions compiled from SVN!
Thanks, I'll test them and see what happens. :)
:cry: Unfortunately the build factory's drivers won't work...
The multi_audio.media_addon on Haiku is named hmulti_audio.media_addon and changing the name or linking to it does no good. Zeta doesn't detect the auich or new mixer either. I reckon you'd have to replace the entire media component to Haiku's to get it to work at all? So what is so special about Jerome's builds then?
I'm beginning to suspect Jerome built his Haiku sound drivers especially for Zeta.
Oh, I didn't think about it... those are probably compiled for R5, not zeta... there's a "target platform" variable that must be set to zeta when compiling them... and I'm positive that the build factory doesn't use it.
Sorry 'bout that ;)
No biggie, I could just build these drivers myself - for Zeta, right? 8)
