Sound theme for Haiku
Forum thread started by Skfyr on Fri, 2005-03-11 07:26
I decided to replace this post everybody can find and use it faster.
These are sounds for comprter poweroff (not for restart!!) There are two different versions of this sound, you can us one wich you like more.
www.zaira.ru/exit1.wav
www.zaira.ru/exit2.wav
Hereafter
This is starup sound
(it was resulted rather budger :-) )
www.zaira.ru/start.wav
This is new mail sound:
www.zaira.ru/mail.wav
And finaly, this is error sound (fatal :-) )
www.zaira.ru/error.wav
One more sound.
This is sound for standart system messages
There are two versions
www.zaira.ru/standart.wav Tone defeat version
www.zaira.ru/standart2.wav Louder version
And...
Systemchoice sound
www.zaira.ru/questionchoice.wav
USB On sound
www.zaira.ru/usbon.wav
and USB Off sound
www.zaira.ru/usboff.wav
pop-up message sound
www.zaira.ru/popupmes.zip
Explore starting sound (when you opening the directory or hard/cd disk)
www.zaira.ru/open.wav
Experemental sounds
User enter (change user operation)
Can be used for another operations like connect/disconnect
www.zaira.ru/usrenter.wav
User exit
www.zaira.ru/quitusr.wav
Conclusive sound
Erasing files from the recycle-bin (realy forever :-) )
www.zaira.ru/erase.wav -voice & instrumental version
www.zaira.ru/erase2.wav - voice only
www.zaira.ru/erase3.wav - another voice only
Most sounds have been updated. To download them go to the first message!! :-)
Wow, those are all really beautiful.
Thank you, I endeavored :-)
First of all. They're all great. :D
Unfortunately, they play for too long (11 seconds is way too much) and all aren't appropriate for desktop sound events.
Here's my advice: listen to Windows sound schemes, you'll know why the sounds you did don't fit in.
I think they fit just fine. There are times when a short sound is needed, but new mail and startup can be as long as one would like.
You are right. I try to use them in Windows like a test and them work OK.
Much better. :D
2 thumbs up! :lol:
No, I am not fully pleased... This evening update will be done.
Well I really enjoy them and look forward to more. : )
Conclusive sound
I generally dont like any sounds, since:
a) - it gets quite annoying after a while
b) - it interupts any MP3's I'm listening to.
c) - it consumes more system resources, since they have to live in memory in order to be played. It especially makes startup longer.
But as a fad for newcomers it's OK, but it's generally the first thing I disable when I install a new OS.
Peope are different I guess.
I personally can't stand startup and shutdown sounds...they essentially serve no functional purpose. Error sounds are useful, and the occasional alert (like for emails and whatnot) can be useful if you're not looking directly at your screen (across the room?) -- but I agree, I listen to MP3s most of the time, and sounds just annoy me when i'm doing that.
Otherwise the sounds done by Skfyr are pretty calm and soothing for the most part.
