Staccato audio
Forum thread started by mounty on Tue, 2009-09-22 01:42
HP Omnibook 500. A fairly low-spec. laptop with a Pentium III and 256 MiB RAM.
Audio 'pulses' at the rate of about 3 Hz. Surely even this low-spec. machine ought to be able to handle a simple .wav file ?
Re: Staccato audio
It may be a driver or interrupt problem.
Though one thing to try is locate the text file "kernel" (Query: Alt+F) and uncomment the line
# serial_debug_output false
	# disables serial debug output, default is enabled
Then reboot.
The serial debug output is known to cause some timing trouble in some configurations.
HTH
Humdinger
Re: Staccato audio
Hmm, tried that thanks, no change. I disabled smp as well as the machine is definitely uniprocessor.
The MediaPlayer is a bit wonky as well but this is alpha of course.
Re: Staccato audio
it seems several people have problem with the audio quality:
http://www.haiku-os.org/community/forum/playing_music
