Use PE help me
Good morning, Sorry I am not English but French then I use a translator. I have install Haiku Alpha on VirtualBOX and when I use PE I can not go back has it the line is normal? his mark her:
http://nsa09.casimages.com/img/2009/09/26/090926095444793898.png
Re: Use PE help me
If no one helps you here on this forum, then you should check out the forum on http://www.beosfrance.com
You will find that the developers who are French post there(In French) , but not here (In English).
