(wifi firmwares) well, this certainly doesn't look right
Forum thread started by Sarreq Teryx on Tue, 2013-06-18 01:09
I don't think I'm doing anything wrong here...
Welcome to the Haiku shell.
~> install-wifi-firmwares.sh
Installing firmware for iprowifi2100 ...
gunzip: stdin: unexpected end of file
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
... firmware for iprowifi2100 has been installed.
Installing firmware for iprowifi2200 ...
... firmware for iprowifi2200 has been installed.
Installing firmware for broadcom43xx ...
bzip2: Compressed file ends unexpectedly;
        perhaps it is corrupted?  *Possible* reason follows.
bzip2: No error
        Input file = (stdin), output file = (stdout)
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover' program to attempt to recover
data from undamaged sections of corrupted files.
tar: Child returned status 2
tar: Error is not recoverable: exiting now
/bin/install-wifi-firmwares.sh: line 271: cd: b43-fwcutter-012: No such file or directory
Downloading http://cgit.haiku-os.org/haiku/plain/src/system/libroot/posix/glibc/stri... ...
2013-06-17 22:01:02 URL:http://cgit.haiku-os.org/haiku/plain/src/system/libroot/posix/glibc/string/byteswap.h [1489/1489] -> "/boot/system/data/firmware/broadcom43xx/b43-fwcutter/byteswap.h" [1]
Downloading http://cgit.haiku-os.org/haiku/plain/src/system/libroot/posix/glibc/incl... ...
2013-06-17 22:01:08 URL:http://cgit.haiku-os.org/haiku/plain/src/system/libroot/posix/glibc/include/arch/x86/bits/byteswap.h [4592/4592] -> "/boot/system/data/firmware/broadcom43xx/b43-fwcutter/bits/byteswap.h" [1]
Compiling b43-fwcutter for installing Broadcom's firmware ...
... failed to compile b43-fwcutter.
...failed. broadcom43xx's firmware will not be installed.
Installing firmware for marvell88w8335 ...
gzip: stdin: unexpected end of file
tar: Child returned status 1
mv: cannot stat `/boot/common/cache/tmp/wifi-firmwares/share/examples/malo-firmware/malo8335-h': No such file or directory
mv: cannot stat `/boot/common/cache/tmp/wifi-firmwares/share/examples/malo-firmware/malo8335-m': No such file or directory
... firmware for marvell88w8335 has been installed.
